94 1.8 tb(on a 12v 4g15) http://4g61t.org/forum/viewtopic.php?f=29&t=6012 |
Author: | Evotistical [ Tue Nov 04, 2003 9:13 pm ] |
Post subject: | 94 1.8 tb(on a 12v 4g15) |
for 50$(sutiban treated me to one) it works great, i ajusted the idle its almost purring like a kitty, low end power is up probly 3 hp(a large gain on a 1.5), and it dosnt cut out if i start out in first with out raising the rpms.high end didnt gain much, but throttle response is instant now. to those who are newbies, after installing, i just set the idle and drive for 20 min then idle for about 20 min. after a days driving it should be set perfectly. dont reset the ecu just let it learn by itself.resetting the ecu will take twice as long for the ecu to recognise it. i looped the coolant lines too, but for you guys in the northern states i wouldnt recomend it cause it probly make cold starts a bitc#. swap took about 20 min after doing it twice. any ?'s pm me or sutiban. oh and worth it? yep if ya got the dough. |
