It is currently Mon May 20, 2024 6:49 pm
PostPosted: Tue Jan 27, 2009 11:32 am
after looking around here for ideas on breaks and not finding anything thought i would make a topic on it. what kind of brakes do you guys use and what is it made of? i was thinking of just getting some Semi-Metallic break pads but i heard that it can wear out the rotors too on some cars. is this a bad materiel to use on the stock rotors or should it be fine?
sorry if there is a topic in another section on this but i looked about everywhere i could think of before making this. thanks for advice.
i have 94 mirage BTW if need to know that.
PostPosted: Tue Jan 27, 2009 2:45 pm
Semi-Metallics make a lot of noise and produce a lot of dust, but generally offer decent braking performance. With a Mirage you're limited to whatever you can find, so you'll probably be stuck with semi-metallics or organics. Ceramic pads work well for noise and dust, but usually fade pretty easily under hard braking. I run PBR Metal Master pads on my Mirage front and rear, and so far so good.
PostPosted: Tue Jan 27, 2009 9:14 pm
oh ok. guess have to look that up. advanced auto parts actually has a lot to choose from looking at there site.
http://shop.advanceautoparts.com/Produc ... s%2c+Front
http://www.oreillyauto.com/EW3/DisplayT ... Count=1861
was also looking at the
Raybestos Raymold they are cheap though at $20.
Brake Pad Set: Raymold Organic; Front; OE Organic.
http://shop.advanceautoparts.com/produc ... 19&PTSet=A
guess i will go with the
Wearever Silver Pad; Semi-Metallic; OE Replacement for $22
hope links work.
PostPosted: Tue Jan 27, 2009 9:29 pm
oh ok. guess have to look that up. advanced auto parts actualyl has a lot to choose from looking at there site.
The base model cars are a lot more common than the turbo cars, so that makes sense.
PostPosted: Wed Jan 28, 2009 12:21 pm
I use Duralast Golds from Auto Zone for my 89 Mirage Turbo. They are a life time warranty and they stop the car very well. :)
PostPosted: Wed Jan 28, 2009 1:29 pm
Lifetime warranty brake pads are a scam. They only warranty the pads if they are worn totally evenly, and the parts they use are inferior to begin with.
PostPosted: Thu Jan 29, 2009 10:19 am
that is why you crack the pad then bring it in to get replacement when it is time to replace them :p
PostPosted: Thu Feb 05, 2009 1:49 pm
Well, Duralast Golds have always done well for me and I have never had a problem with getting a new pair for free for Auto Zone... :butthead:
PostPosted: Thu Feb 05, 2009 4:49 pm
what kind of rotors are you using now? i heard the lifetime breaks eat up rotors which is something i don't want.
PostPosted: Thu Feb 05, 2009 4:52 pm
Any metallic pad is gonna eat up the rotor, it just depends on how much metal content the pads have--some are worse than others.
PostPosted: Sat Feb 07, 2009 2:56 am
which is one reason i was asking to see what ones worked good and lasted a while without damaging the rotors enough so will i need to turn rotor or get new ones before break need to be replaced again. :p
PostPosted: Wed Feb 11, 2009 11:34 pm
do the turbos have different breaks then the base model brakes? wouldn't think they would do something like that.
i am rethinking the wearever brakes now so guess that means i am still looking now. really need to decide soon since there really is no brake left. it is practicably to the metal i think. oh well guess might need to get rotors turned unless that is more money then new ones.
PostPosted: Wed Feb 11, 2009 11:54 pm
do the turbos have different breaks then the brakes? wouldn't think they would do something like that.[/quote]
Yes, turbo brakes are significantly larger. The pads and rotors are bigger, and the calipers are different as well.
PostPosted: Thu Feb 12, 2009 12:52 pm
Yes, turbo brakes are significantly larger. The pads and rotors are bigger, and the calipers are different as well.[/quote]
I always thought the sedans and the turbo models had the same type front brakes.
PostPosted: Thu Feb 12, 2009 1:15 pm
Just 1.6L sedans.
