SuperPro Polyurethane Bushing Kit http://4g61t.org/forum/viewtopic.php?f=29&t=12004 |
Page 1 of 2 |
Author: | HondaHunter [ Mon Dec 13, 2004 1:28 am ] |
Post subject: | SuperPro Polyurethane Bushing Kit |
Installed the front kit this weekend(Front & Rear controll arm bushings and sway bar endlink bushings) and the ride is a bit more stiffer but i really like it. gain a bunch of road feel now from the less flexing of the poly's. easy to install if you have a press( and what i means by this is you need the press to remove the old ones, or be carefull when sawzall'n them off as another board member said). i removed both controll arms from the car, and pressed all of the old bushings out. the poly kit comes with its own white lithium type grease packets and the bushings press right on without the aid of hand tools.. highly recommend them if you're in the market for upgraded bushings. the only part of the kit that i didnt get to was the panhard rod bushings. those need to be pressed out and the new ones pressed in. - Paul |
Author: | colt-r-old [ Wed Dec 15, 2004 3:49 pm ] |
Post subject: | |
Do you think theres any way to use a c-clamp to remove the old bushing? Im waiting for mine in the mail from Jason right now. I hope i have the same results as you. |
Author: | LILEVO [ Wed Dec 15, 2004 4:01 pm ] |
Post subject: | |
Who has the front bushings? I need some eventually |
Author: | colt-r-old [ Wed Dec 15, 2004 4:04 pm ] |
Post subject: | |
Jason V does, but apparently won't have any for another 2-3months. |
Author: | HondaHunter [ Wed Dec 15, 2004 11:05 pm ] |
Post subject: | |
yes DSMracer is selling the kits. i bought one of the last kits he had from the first shipment. plus i HAD to buy one since im Head of R&D....so it was mandatory. and dom, i dont think c-clamps would work - Paul |
Author: | LILEVO [ Wed Dec 15, 2004 11:37 pm ] |
Post subject: | |
Author: | netninja2001 [ Thu Dec 16, 2004 12:00 am ] |
Post subject: | |
actually i just talked to him the other day. his supplier found some more so they're available again (though i don't know how much they found...) |
Author: | HondaHunter [ Thu Dec 16, 2004 12:08 am ] |
Post subject: | |
Quote: $$?
www.evol-art.comthe pricing is on there. - Paul |
Author: | dsmracer [ Thu Dec 16, 2004 12:44 am ] |
Post subject: | |
http://www.evol-art.com/suspension_brak ... hings.html to be exact. I goofed on the Full Kit pricing. It's $95 for a Full Kit, $105 for a Full Kit w/Rear Swaybar. I just fixed the site but sometimes it takes a bit for the server to update. |
Author: | netninja2001 [ Thu Dec 16, 2004 12:52 pm ] |
Post subject: | |
*smiling ear to ear* beats the 145 that was there |
Author: | Berserko [ Fri Dec 17, 2004 8:04 am ] |
Post subject: | |
Quote: Do you think theres any way to use a c-clamp to remove the old bushing?
I wrote a write up on how to remove them and you don't want to use a c-clamp trust me I tried.
Author: | ColtMax [ Sun Jan 09, 2005 7:27 pm ] |
Post subject: | |
Quote: Quote: Do you think theres any way to use a c-clamp to remove the old bushing?
I wrote a write up on how to remove them and you don't want to use a c-clamp trust me I tried.Im waiting for mine in the mail from Jason right now. I hope i have the same results as you. there are very easy to remove ounce you get the touch... |
Author: | Mirage2.0 [ Wed Jan 12, 2005 9:35 pm ] |
Post subject: | |
I need to replace everything on the front swaybar, so what do I need???? |
Author: | HondaHunter [ Wed Jan 12, 2005 10:53 pm ] |
Post subject: | |
Quote: I need to replace everything on the front swaybar, so what do I need????
the endlink bushing come in polyurethane. the bushing that bolt to the body of the car can be ordered for any part store or the dealer |
Author: | Mirage2.0 [ Thu Jan 13, 2005 8:21 am ] |
Post subject: | |
Yes well the part that wraps around the swaybar and connects tot he body of the car is made in poly also just trying to find it. |
