It is currently Fri Apr 26, 2024 1:35 am
 Post subject: Help with wiring
PostPosted: Wed Jun 23, 2004 8:15 am
Hi
I'm wiring my alarm and just want to be sure to understand this section of the wiring diagram
do someone can tell me exactly what to do with each wier from the relay ( 2 green:(big) a yellow and a white (small))
the yellow wire is coming from the main module
Thank you
PostPosted: Thu Jun 24, 2004 3:06 pm
yellow: input from alarm
green: cut your starter wire...and attach the starter side to pin30 on the alarm and pin 87a to the starterside of the cut starter wire
White: is the coil side of the relay..connect to constant 12v. pending your alarm is throwing a neg(-) to enable the starter kill
http://www.clubgp.com/newforum/upfiles/ ... d93156.gif
