It is currently Thu Mar 28, 2024 6:01 am
 Post subject: dash speakers
PostPosted: Sun Sep 28, 2003 1:16 pm
ya know those speakers under the dash in a '92 colt 200?(is there like a generation thing you guys use I could reference to instead of refering to the exact year and model all the time?). I havn't pulled em out yet(not important enough yet) but what size are they and are the hard to upgrade?
RIP- '92 Colt 200E, 12valve 4G15, 5spd.
'89 Colt 200E, stock 8valve 4G15, 5spd,
 Post subject: speakers
PostPosted: Sun Sep 28, 2003 2:09 pm
They're dead easy to upgrade. I think they are 3.5 inches, don't remember exactly tho.
PostPosted: Sun Sep 28, 2003 3:04 pm
They're 100 mm = 4 inches. The time-consuming part is getting this part of the dash disassembled. However it is straight forward.
Got rabies?
 Post subject: Re: dash speakers
PostPosted: Mon Oct 13, 2003 8:19 pm
YES. :)
http://www.4g61t.com/forum/viewtopic.php?t=4041
Witty Signature Goes Here!
PostPosted: Thu Apr 15, 2004 6:56 pm
What are the speakers that go in front of the hatchback...... 90. I'm talking about the one that sits right off/above the left knee when you are sitting at the wheel. What size? Are these the ones you guys were talking about? I want to get some good ones for the front since my back ones were updated. Thanks
http://www.angelfire.com/oz/plymouthcolt/index.htm
1990 Plymouth Colt GL
4g15
_______________________
Szymon Zmijewski
Sierrazulu85@Aol.com
PostPosted: Thu Apr 15, 2004 8:02 pm
Those are the 4" ones mentioned earlier, I believe. and mine were WAY easy to get out... the speaker grille cover just pops off, and then you pull a couple of screws and the speaker comes out. I'm checking around to see if I can find something decent (like Polk Audio) that will be a direct replacement...
Now, the ones in the door are a bit more work, as you have to pull the door panel off to remove the speaker.
Been out of the scene for a while, looking for another factory turbo Colt/Mirage
PostPosted: Wed Apr 28, 2004 5:43 pm
Yep these speakers are 4" and deadd easy to remove. Ive got a set of 100wrms Jaycar speakers in there (do you have this brand in america? Jaycar are an electronics store)
Many reviews have been conducted on speakers of this size and the quality of the jaycars is comparable to much more expensive and higher end brands (and they only cost $100aud a set!)
Mike
Member #31
PostPosted: Wed Apr 28, 2004 8:19 pm
I have a set of 4" Kicker resolution for front stage their quite nice handle lots of power too
PostPosted: Wed May 19, 2004 6:53 pm
i have put in 4" Mac Audio´s with real high quality Sound.They are connected to an AMP.
Lancer C68 4G67t
Eclipse D22 4G63 Cyclone
Eclipse D27 E316g,too much to List here.
Galant EA0 V6-24V
