speaker amp? sub amp? which get the sub out. http://4g61t.org/forum/viewtopic.php?f=28&t=5369 |
Author: | colt-r-old [ Sun Sep 21, 2003 2:45 pm ] |
Post subject: | speaker amp? sub amp? which get the sub out. |
on my deck i have two outputs. My speaker amp which i got for free (but i know it works) has the inputs, but then my sub amp has the same inputs.. how to i wire this bad boy, they both use the same inputs and i can only use one at a time. Do i need to buy some sort of spliter? maybe a better deck would solve my problem its a crummy 35x4... maybe if i got a 55x4 mosfet my 6/9's wont distort... any suggestions? i have a 10' kicker and 12' MTX, maybe my buddy will give me his deck. |
Author: | MirageGS [ Sun Sep 21, 2003 10:16 pm ] |
Post subject: | |
well i used a set of splitters since my old sanyo cd/cassete deck only had one amp output. my old kenwood amp had two sets of inputs to work all four channels. so thats wut i did. the big draw back i guess that using the splitters is it turns your one 2volt output into two 1volts outputs. cuts sound quality down. but hey beats the heck out of buying a new deck. if you do get a new deck wut would be best is to get one with a 4volt sub specific output and an second 2volt set of outputs |
Author: | socrateez [ Mon Sep 22, 2003 6:40 am ] |
Post subject: | |
Splitter.Or.... some amps have output jacks so you can plug another amp in as it sends the signal back out. My Legacy amp has this feature. I used to have another amp hooked to it driving the rear deck speakers. Also, If its a bridgeable amp, you can run it with the sub bridged and your L&R speakers hooked normally. I tried this for awhile too. If it can be hooked up a certain way, i have to try it out. |
Author: | kjmerkel69 [ Mon Sep 22, 2003 9:54 pm ] |
Post subject: | |
Another idea would be to get a standalone preamp. front in, rear in, then front out, rear out, and sub out. Look into it. |
Author: | Berserko [ Wed Sep 24, 2003 6:23 pm ] |
Post subject: | |
Goto a pawn shop you find all sorts of hot stereos in there that have 2 outputs thats what i recommend... |
Author: | socrateez [ Thu Sep 25, 2003 7:44 pm ] |
Post subject: | |
Pawn shop...yeah. Good stuff for half the price of new! Or...if you live in a neighborhood with lots of crack-heads, you can get just about anything from them for $20. |
