The easiest swap will be from an '86 Turbo model with a G32B motor. You'll more than likely have to find a donor wreck in a salvage yard to strip everything from. Radiator, harness, engine/tranny, axles, knuckles/hubs/calipers/rotors, power steering rack, master brake cylinder, fuel lines to the tank and fuel pump. Its a big job. You'll be fortunate to find a donor close by. The '85 and '85 turbo colts and mirages would also be donor candidates.
_________________ Phil Hutchinson
1986 G15B, 1986 G32B, 1988 G32B
