It is currently Sun Apr 28, 2024 4:47 am
 Post subject: look at this pic...
PostPosted: Sun Sep 28, 2003 9:01 pm
and tell me if theres suppose to be a bolt plugging this hole on my tranny. this is looking straight down on the passenger side of my tranny
http://members.shaw.ca/cjdc/pics/92colt ... ISSING.JPG
RIP- '92 Colt 200E, 12valve 4G15, 5spd.
'89 Colt 200E, stock 8valve 4G15, 5spd,
PostPosted: Sun Sep 28, 2003 9:04 pm
umm no. why? because it doesnt go inside the tranny.
The resurrection begins.
90' Plymouth Laser RS Turbo (donor)
90' Dodge Colt (2.3L 4g63T swap)
PostPosted: Sun Sep 28, 2003 9:58 pm
nope, a bolt doesn't go there, but a little black rubber breather is suppoused to be there. You're probably ok w/o it though.
www.freewebs.com/locost
PostPosted: Sun Sep 28, 2003 10:47 pm
ok, just look like a way for crap to get in the tranny. tranny oil and diff oil is all one correct? cause when I pulled the drain bolt thats below the passenger side axle then filled it up through a bolt hole at the front of the tranny(thats I sorda remembered as the fill bolt from a '91 colt I had a couple years ago) it shifted worse than before I changed it, I think I need lighter oil, book said run GL-4 or better so I picked up some 80-90 that said it works for where GL-4 or 5 is called for. hmmm, have to deal with it once its actually on the road, temp permit ran out so gotta wait for truck to sell.
PostPosted: Mon Sep 29, 2003 6:21 am
Never EVER use any GL-5 oil on Mitsu trannys. It will eat the syncros. 80-90 is a heavy oil. It works, but shifting is a nightmare when it's cold outside. A lot of people said Castrol VMX80 is great, but I don't know (and couldn't find out) wether it's GL-5 or GL-4. Does anyone know?
Got rabies?
PostPosted: Mon Sep 29, 2003 8:12 am
I use half Redline MT90 and half MTL in both of my cars. VFAQ has a lot of good info on fluids.
-Tuan-
'89 Colt GT Turbo
'91 GVR-4 #1421
PostPosted: Mon Sep 29, 2003 8:20 am
hrmm I have no idea what those oils are
PostPosted: Mon Sep 29, 2003 8:38 am
Just for future reference, try to make the title a little more clear about the subject of the post.
If someone searches for transmission and this title pops up, they most likely are not going to look at it.
PostPosted: Mon Sep 29, 2003 7:00 pm
I use BG SynchroShift and it seems to work well. In addition, it has virtually no odor.
Witty Signature Goes Here!
PostPosted: Mon Sep 29, 2003 7:09 pm
BG Synchroshift or GM Synchromesh is the ONLY thing to put in a DSM tranny. I have tried 4 or 5 others, and none of them even come CLOSE to these.
The entire DSMHawaii car club SWEARS by these products.
-Kev
Cheap, Fast, Reliable......you can only pick <b>TWO</b>.
PostPosted: Mon Sep 29, 2003 10:37 pm
yah I know, I wasn't intending to switch topics but it kinda happened, maybe I should create a tranny oil thread?
PostPosted: Tue Sep 30, 2003 1:18 am
oh yeah i forgot about that little sucker. i retract my prevous statement. you do need that breather tho. it keeps water and dirt out.
