It is currently Tue Jun 04, 2024 7:41 am
PostPosted: Mon Sep 15, 2003 2:09 am
Ok so i goto put new spark plug wires on my 61t, and ended up forgeting wich spark plug wire goes to wich coil, so i guess im wondering wich of the 4 coils is wich ( what is the firing order, ie. cylinder #1,2,3,4, goes to wich coil), thanks, i just wasnt thinking straight at the time.
White 89 colt GT Turbo
tuxedo 91 1GA TSI auto
Silver 91 previa
Silver 2006 G35 6spd Sport sedan F.S.
 Post subject: spark plug wires
PostPosted: Mon Sep 15, 2003 11:38 am
nobody knows? the coil has 4 plugs in a row, wich plug goes to wich cylinder?
Silver 91 previa
PostPosted: Mon Sep 15, 2003 11:49 am
I believe that it's 4-1-2-3
PostPosted: Mon Sep 15, 2003 12:28 pm
so do you mean, that the 1st plug in the coil goes to #4, 2nd plug to #1 and so on?
"I believe that it's 4-1-2-3"
so if you labled the cylinders from left to right 1-4 does that mean that cylinder 1 goes to coil plug 2, cylinder 2 goes to coil plug 3, cylinder 3 goes to coil plug 4, and cylinder 4 goes to coil plug 1?
thanks im just kinda confused.
Silver 91 previa
PostPosted: Mon Sep 15, 2003 1:29 pm
I think you're right, except for the cylinder labeling. Cylinder #1 is right beside the timing belt. So the numbers go from right to left.
PostPosted: Mon Sep 15, 2003 3:37 pm
For the archives:
On 4G6x the firing order is 1-3-4-2.
The outputs on the ignition coil(s) is 4-1-2-3, 4 being closest to the front of the engine and 3 being closest to the firewall.
As 4G6x use a waste spark system, cylinders 1&4 and cylinders 2&3 are fired together.
If cylinder 1 is to be fired, 4 will fire also. Therefore, you could also route you wires 1432, for example.
Got rabies?
PostPosted: Mon Sep 15, 2003 7:20 pm
BANNED FOR FRAUD
This system is known more accurately as a 2-Channel ignition system. This also means to properly upgrade it you need two ignition amplifiers. This is why most upgraded plugs and wires alone sometimes hamper performance. The spark also needs to be boosted, and done so properly.
Jason Veraldi
Scammer
PostPosted: Tue Sep 16, 2003 4:28 am
2-channel-system is the correct and official designation, I think. I wouldn't want to tamper with the stock ignition system, though, and go aftermarked it the need arises.
Got rabies?
