It is currently Fri Mar 29, 2024 4:37 am
 Post subject: small 16g
PostPosted: Thu Oct 08, 2015 8:16 am
Hello! I have a problem, i change turbo 14b for small 16g, but 16g dont charge... Hello me please!
 Post subject: Re: small 16g
PostPosted: Thu Oct 08, 2015 9:05 am
At idle, see if the compressor is spinning. check for shaft play. Make sure the waste gate has the proper preload. Those are just a few reasons that cause boost lag.
PostPosted: Thu Oct 08, 2015 11:20 pm
and check the piping, check the wastegate everything works, the propeller rotates and is in good condition, I just have a question, does the turbo 16g can be used with OEM manifold?
PostPosted: Thu Oct 08, 2015 11:31 pm
Yes it can be used with the OEM manifold. It's the same exact thing as a 14b, but with a different compressor wheel
