It is currently Thu Mar 28, 2024 3:15 am
 Post subject: turbo small 16g
PostPosted: Sun Sep 27, 2015 4:58 pm
Hi, I want to put my colt turbo 16g small, I want to know what else I should change my colt?
Now I have to swap 4g61 engine 1700cc, compression 8.6 turbo14b, 450cc injectors intercooler Mitsubishi Eclipse 2g and 2 inch pipe, what should I change to get the best result of this 16g turbo? Thank you!!
 Post subject: Re: turbo small 16g
PostPosted: Mon Sep 28, 2015 8:25 am
Dsm link
PostPosted: Mon Sep 28, 2015 11:51 am
I would use the 14b 6cm exhaust housing. the 7cm will be too laggy with 1700cc
PostPosted: Mon Sep 28, 2015 9:21 pm
lancerman, any benefit to using an Evo3 intake manifold or does it share enough similarity to the stock 4g61t ports and plenum volumes, that it would be pointless to split hairs at this powere level? Or does it not fit a 1G head anyways? I'm not 100% versed on the 1G head / 2G head and intake flange differences.
PostPosted: Mon Sep 28, 2015 9:52 pm
the 4g61 ports are neither 1g or 2g. they are kinda in between. the evo3 manifold is only a good idea for the 2g head ports.
