It is currently Fri Apr 26, 2024 9:37 am
 Post subject: fuel pump
PostPosted: Fri Jan 16, 2015 11:40 pm
I need help, my colt 4g61t not start, I discovered that no electricity to pump gasoline, but the main relay is good, what should I do? help me please. :cry:
 Post subject: Re: fuel pump
PostPosted: Sat Jan 17, 2015 12:24 am
I would check for a CAS/CMP signal. The computer won't ask the pump to turn on unless it knows the engine is cranking.
That's all I've got. Adios, and godspeed Amigo!
PostPosted: Sat Jan 17, 2015 7:21 pm
Thanks, I already solved the problem, everything was due to the ground of the fuel pump loosened!
