It is currently Wed Apr 24, 2024 11:27 am
 Post subject: What j pipe to run?
PostPosted: Sun Oct 26, 2014 12:30 am
For a colt gt with stock radiator and fan, what j pipe are you guys running? Passenger facing or driver facing? I would like to refrain from going over the top of the manifold. I may run a side mount ic. Basically I'm just curious if these cars have room to fit a j pipe with little trimming, the space looks too tight.
 Post subject: Re: What j pipe to run?
PostPosted: Sun Oct 26, 2014 7:33 am
I have a hard pipe welded to a stock flange, aimed to the passenger side. Just barely clears the stock turbo fan shroud,
in fact I have the shroud bent just a pinch to make up for clearance just in case, even with mount inserts at all four corners.
The pic shows what the pipe looked like installed on the M&S Recycling Colt, that Jon Reimer built.
PostPosted: Wed Oct 29, 2014 4:16 pm
Can a non-staff member let me know if they can see the photo Tim posted?
PostPosted: Wed Oct 29, 2014 8:02 pm
im a staff member and I see this in red at the bottom of his post in smaller letters...
You do not have the required permissions to view the files attached to this post.
PostPosted: Thu Oct 30, 2014 12:51 am
That's what I figured. This subforum isn't setup for pics.
PostPosted: Thu Oct 30, 2014 9:59 am
We see this "You do not have the required permissions to view the files attached to this post." also.
PostPosted: Sun Nov 02, 2014 11:50 pm
I have one. it's not pretty but it worked for exactly what you want.
Open to offers
http://www.ebay.com/itm/89-92-Dodge-Col ... 258e171981
Installed pics:
http://lilevo.com/lilevo2/fmic/final/
PostPosted: Mon Nov 03, 2014 4:48 am
I run this one:
http://www.punishment-racing.com/punish ... pse-talon/
http://www.4g61t.org/forum/viewtopic.php?f=2&t=27325
It might not fit with a stock radiator though.
Got that right.
