It is currently Mon Jun 03, 2024 9:08 pm
PostPosted: Tue Jun 03, 2014 1:19 pm
i pulled my struts because i have been coming up with a plan for diy coilovers.
the kind where you slip a collar over the struts and add a 2.5" coilover spring.
i noticed this little bump near the top of the strut.
it is going to be in the way of sliding my sleeve on so has anyone seen this?
can i file it off? or is that the factory oil fill plug or something (only thing i could think of)
i certainly don't want to ruin my struts :lol:
thanks for looking
PostPosted: Tue Jun 03, 2014 2:45 pm
Probably a fill plug of some sorts, not sure if you can grind it off, you might open the fill hole back up.
PostPosted: Tue Jun 03, 2014 2:48 pm
Just notch the sleeve a little to slip over it. Your weld will easily fill the notch.
