It is currently Fri Apr 19, 2024 11:06 am
PostPosted: Mon Mar 25, 2013 2:27 am
Hi! i was searching on the Autozone and Napa parts catalog about interchangeability between 4g15 and 4g61 mounts, and i found out that their catalog claims different 4g15 part number mounts for Dodge and Plymouth Colts than Summit and Mirage, if you look for Summit and Mirage 4g15 mounts they say that 4g15 mounts are the same with the 4g61 ones, could somebody explain this?
PostPosted: Mon Mar 25, 2013 6:53 am
To my knowledge the only interchangeable mounts between the 4g61 and 4g15 is the front mount, the other three mounts are not the same. Don't trust those parts chain catalogs, they are wrong 75 percent of the time. So to make it clear all 89-92 Colt/Summit/Mirage mounts are exactly the same for there corresponding engines i.e 4g15 or 4g61. If you are looking for mounts RockAuto has them in stock.
PostPosted: Mon Mar 25, 2013 8:20 am
This!!
Rockauto lists the correct mounts. The standard auto chains tend to change information daily. Sometimes they are very good (if you go into the store), but their online information is about as accurate and reliable as Wikipedia.
PostPosted: Mon Mar 25, 2013 11:05 am
Just as i tought, well actually rockauto has some issues too with their catalog after you look up for 90-92 CSM's mounts, but just like you said, for the 89' Mirage Turbo has the right mount part numbers...
PostPosted: Mon Mar 25, 2013 12:33 pm
You got to remember that csm's were offered in a na 4g61 also, so if it has a 1.6 engine option under the model drop down then it should have the same mounts as the turbo 89's. But like you said just double check the part numbers.
Users browsing this forum: No registered users and 21 guests
