It is currently Wed Apr 24, 2024 1:58 pm
 Post subject: 4 speed or 5 speed
PostPosted: Tue Dec 04, 2012 12:00 am
Im trying to search on here and forgive me if its available and I cant find it. Just curious if the 4 speed was problematic and should just keep my eyes on a 5 speed none turbo colt. reason i mention 4 speed someone is trading there colt local to me. I might just give up my 1g turbo dsm due to work cutting hours and what not. My commute is pretty long
-89 Mitsu Mirage 1.5
 Post subject: Re: 4 speed or 5 speed
PostPosted: Tue Dec 04, 2012 12:20 am
There never was a 4spd. turbo colt, they were all 5spd. The non-turbo cars were available in 4spd or 5spd. You want a 5spd, for lots of reasons. The 5spd is stronger, and the 5spds were also all hydraulic clutch, where-as the 4spd is cable.
PostPosted: Tue Dec 04, 2012 3:32 am
I meant to say none* turbo colt. i know there was a 4speed and 5 speed manual trans. Thanks for the information
PostPosted: Tue Dec 04, 2012 8:52 am
I had issues with my 4 speed popping out of 1st and 2nd with a little over 100k on it so I would opt for the 5 speed.
PostPosted: Wed Dec 12, 2012 9:10 am
I would look for the 5spd as mentioned above, stronger, and extra gear gets you better mpg, even though i used to get about 35+mpg with the 4spd.
PostPosted: Fri Dec 28, 2012 3:15 pm
4 Speed I've had bad luck with less than ~100k miles would have to repair/rebuild. The cable clutch on it is flimsy that was the thing that cost me the most owining the Base model Colt. It has ~225k miles. ~40mpg PS: OE Clutch Cable ~$100 but I learned to go to Big R or Farm Store and buy the same Diameter size Wire Rope and that ran me $4 and did the job for about 6 months :P Had to change it after winter.. and again after summer.
5 Speed in the Colt GL with Hydro Clutch is nice! Easy to shift and havn't had to work on it much! ~300k miles on it and finally tearing out the engine to rebuild and might rebuild the tranny since it is out but... It aint broke so I might just leave it alone!! :P ~50mpg
The Colts have always been a Daily Driver and getting ready to do a face lift on the colt. When i get a little more free time. But theres my 2 cents hopefully it helps ya out.
~Ken
'91 Colt - Ongoing work in progress.
http://4g61t.org/forum/viewtopic.php?t=37446
^Check Build Thread^
'82 Chevy El Camino Tow Veh. for my 2012 Skyline Koala 24' Travel Trailer
'06 Chevy Aveo - Daily Driver until Colt is back up and running!
