It is currently Thu Apr 25, 2024 5:06 am
PostPosted: Fri Apr 06, 2012 4:18 am
Hi there,... soo.. im thinking about getting a 1g talon and a 4g 95 mirage and doing a swap. What difficulties would i be going through and would it just drop in? I was doing a 1g swap to a 3g csm a year ago but never got to it and had to abandon it. I can get both cars for 1200. I have 90 harness, engine mounts for a 1g motor to 3g csm, harness adapter ( i think its was only made for 89-90 talon years as the other years are a bit different ) from the previous failed project.. Now would my mounts that i have fit for this swap (94mirage+1g4g63) Also would i be able to use the 1g engine harness instead of the 4g harness or have to mock up the 4g harness, if so which/what plugs/wiring would i be looking into? thanks
Build it, Race it, Break it, REPEAT!!!!
PostPosted: Fri Apr 06, 2012 4:22 am
I know this is a csm site but i'll try my luck,
PostPosted: Fri Apr 06, 2012 8:57 am
The 4g cars are completely different in every way except that the engine and trans are still on the right side so at least the engine/trans will work. However you will need custom mounts and a different adapter harness for your 1g engine harness. If you're not planning on making a ton of power you can source a 1.8 F5M22 trans from a 93-96 csm and it will bolt to the 4G63 if you use a smaller na flywheel/clutch combo. I believe you can use a 2g dsm t-belt mount along with the stock mounts from the 1.8 trans and it will all bolt right in.
If you want to use a 1g dsm transmission you will have to make custom mounts and roll stops for the front, rear and top transmission mounts. A 2g dsm trans will bolt in but then you have to source axles from a 92.5-94 fwd turbo dsm since they have the larger inner axle stubs.
Hope this helps! Also if you are planning to do a manual swap I have a rare set of LS hydraulic pedals laying around should you need them. 8)
PostPosted: Fri Apr 06, 2012 1:03 pm
dang, lol. what about the wirings. can i use the 1g harness? if i do the only wiring i would mostly have trouble on is the interior plugs.
PostPosted: Fri Apr 06, 2012 11:05 pm
Yes you can use the 1g engine harness, I make a plug and play adapter if you need one.
Users browsing this forum: No registered users and 47 guests
