It is currently Mon May 13, 2024 11:59 am
 Post subject: Auto tranny ??
PostPosted: Wed Nov 30, 2011 7:41 am
So on my quest to auto swap my red turd, I ran into a great package deal on a dsm 1g non turbo tranny fa22 I beleive, the turbo tranny is fa33 but. Is/has anyone taken them apart? Are the guts the same? Please only helpful info from people that have done this.
89 turbo chili
92 gvr4 96/1000- sold to mois used car lot
 Post subject: Re: Auto tranny ??
PostPosted: Fri Dec 02, 2011 8:22 am
I've never took an auto apart but most of the time the turbo trans will have stronger parts. Depending on your goals hp wise the non-turbo might be okay for yu.
PostPosted: Fri Dec 02, 2011 9:19 pm
What Im trying to get at is that if I can put all the turbo trans rebuild parts in the nonturbo casing and run it, or if the internal parts are not compatible
89 turbo chili
PostPosted: Sat Dec 03, 2011 5:01 am
http://www.importperformancetrans.com/dsmindex.shtml
These guys should be able to help you.
PostPosted: Sat Dec 17, 2011 10:40 pm
Yeah, those guys are garbage. When I had my Subaru Legacy 2.5GT, IPT sold an upgraded valve body for $795. One of the board members purchased their service to get his valve body worked on, put it in the car, and really didn't feel much of a difference. A year later, his auto started slipping so he decided to build his own performance trans. He purchased a second trans and in the process of building it he compared the two valve bodies. The ONLY difference was 1 beefed up spring to change the line pressure. FOR $795!!!!
Well, the Legacy's trans computer is programmed to override the valve body line pressure whenever it read too high through the use of solenoids and magic....... long story short, it was a waste of money. Multiple members logged line pressure table and compared them to members with the IPT valve body and they were the same.
1989 Mirage Turbo - 310whp - Sold
1998 Eagle Talon TSi AWD - Sold
2005 Legacy 2.5GT - Sold
1989 Dodge Colt GT
