It is currently Mon Jun 03, 2024 9:30 pm
PostPosted: Sat Oct 22, 2011 6:36 am
Just courius how this would look on a csm, seen it done on a members car here before I think it was coltsfan car, any how anyone have any pictures of this done, or have better luck searching this?
89 turbo chili
92 gvr4 96/1000- sold to mois used car lot
PostPosted: Sat Oct 22, 2011 8:13 am
I cut this part off a DSM bumper, and glued it to my original bumper using 3M #08609 Super Fast Urethane Window Weld. I little trimming around the license plate, and some two part urethane bumper body filler, and there it is. So far it's been holding for several years with no sign of cracking or failure.
PostPosted: Sat Oct 22, 2011 9:18 am
cool thanks man very good info on that if I copy you dont sue me Im just a poor csm'er
89 turbo chili
PostPosted: Sat Oct 22, 2011 2:37 pm
Ha ha ha, you have my permission, it's not like it's patented or anything.
I had too shorten the part behind the wheel too. I just cut a couple inch strip out of the middle on each side, and glued cut out piece onto the back with the urethane window weld. After it hardened, and was on the car, I filled in the crack with epoxy urethane bumper repair filler.
If you zoom your browser, you can slightly see the line where the filler has shrunken over the years.
PostPosted: Fri Dec 02, 2011 8:24 am
that doesn't look ti bad. You have side skirts that hang down that low also?
