I need to know which gearbox I can run on my 4g61t c53a fwd cyborg, I have a km210 sitting around but Im from newzealand so it's near impossible to source a flywheel to suit it. I was just wondering which model gearboxes will fit? proferably the gearbox that usually comes with a 4g61 n/a as i've got a clutch and flywheel that will fit that gearbox. I know using a non-turbo gearbox isnt that great but I urgently need to get the car going for work etc.
You should be able to use the N/A gearbox no problem. It's the same block, so it will definitely bolt up. The N/A clutch will probably be pretty weak, and your gearing will probably be super short, but you can make it work.
You can also use a 4g63t 4wd transmission if you source an 4g63t clutch and 4wd flywheel. You will have to make some modifications to the shifter cables to do it, but it will work. You'll also have to either weld the center diff in the transmission, or remove it altogether and use a spool or some other type of viscous coupling eliminator.
