gauge setups lets see them http://4g61t.org/forum/viewtopic.php?f=26&t=34517 |
Page 2 of 2 |
Author: | modicaUSMC [ Thu Jun 02, 2011 4:43 am ] |
Post subject: | Re: gauge setups lets see them |
Quote: |
Author: | Flying Eagle [ Thu Jun 02, 2011 8:25 pm ] |
Which seats are those Modical? |
Author: | modicaUSMC [ Fri Jun 03, 2011 12:17 am ] |
Quote: Which seats are those Modical?
there the EVO 9 MR's
Author: | pma1123 [ Tue Aug 02, 2011 1:32 pm ] |
Author: | cloead [ Mon Oct 17, 2011 9:35 am ] |
Do you know where you got your steering hub adapter? |
Author: | pma1123 [ Mon Oct 17, 2011 12:16 pm ] |
My telescoping wheel would slide out when I didn't want it to, so ditching it was a welcome upgrade. To do that, I swapped in a base model steering column and used the same hub that a 1G DSM would use. The telescoping wheels have a much larger taper/splines than the CSM non telescoping/DSM variety. |
Author: | cloead [ Mon Oct 17, 2011 12:57 pm ] |
I've ordered 2 different hub adapters from eBay that are supposed to fit an eclipse/t/l.. neither fit I have a non-gt (non-tilt) colum. |
Author: | bowdown [ Mon Oct 17, 2011 1:55 pm ] |
I beleive I have a spare one...(momo hub adapter) I'll look for it and if your interested I can give it for $45 shipped |
Author: | cloead [ Fri Oct 21, 2011 7:43 am ] |
Quote: I beleive I have a spare one...(momo hub adapter) I'll look for it and if your interested I can give it for $45 shipped
Pm'ed you.. I want it! LMK if you can find it! |
Author: | canada4g63 [ Fri Dec 02, 2011 8:29 am ] |
bowdown your set up is sick bro |
Author: | cloead [ Fri Dec 02, 2011 2:26 pm ] |
Redoing my entire gauge setup this winter.. should be a royal pain in the ass. |
Author: | cloead [ Fri Dec 02, 2011 2:30 pm ] |
Mine as it sits: Looks nice, but you cannot read any of them while driving/racing.. which makes them useless |
Author: | Mechacode [ Sun Dec 04, 2011 5:28 am ] |
All my factory radio wires were hacked by the previous owner so I had no qualms about doing a sheet panel. In the future I plan on something a little cleaner, maybe tucking them into the glovebox or ceiling mount. Gotta find a place for a wideband in there too. I've got, water temp, oil temp, fuel pressure, and voltage down below, boost and oil pressure on the pillar pod. I have no idea what the pod was for originally, I bought it off someone here on the forum and it fits perfectly and matches the oem finish. Everything is electronic senders except for the boost. For running wires, I picked up about 10' of sheathed wire from the local hardware store, lot easier to run one thick "wire" from the dash to the bay than 5 individual wires. The cable down below is for my logger. |
Author: | UnderPSI [ Sun Dec 04, 2011 12:35 pm ] |
How do you like those prosport gauges? I was looking in to running those in green. |
Author: | Mechacode [ Mon Dec 05, 2011 1:46 am ] |
I really like them. Blacked out when off, bright blue when on. The only problem I've had is that the oil pressure sender likes to die when it's mounted to the OFH. I plan on fixing that by remote mounting. The 6 gauges in the pics were about $150 and the wideband that matches was another 200. A place hooked me up with a pretty good deal, pm me if you'd like the name of the shop as they haven't paid for advertising so I won't publically say it. |
Page 2 of 2 | All times are UTC-05:00 |
