It is currently Mon Oct 27, 2025 4:55 am
PostPosted: Sun Jul 16, 2006 9:43 am
went to get my alignment done yesterday and the mech says i need to replace both control arms...
i figured as much because since i had the car it needed an alignment...SO, my question is: other than colt control arms, what else can i use?
one search turned up they fit, BUT come with toe out issues
thanks
1991 galant gsx + 4G63t
1989 colt gt
PostPosted: Sun Jul 16, 2006 10:52 am
There is no toe out issue on mine I have 94 elantra control arms on my one car and 93 on the other. Both align to 0 toe and 1.75 degrees negative camber its nice really give me fantastic turn in very neutral very little understeer with my current setup...
LC '01 Accent GSI - Silver
 Post subject: great...
PostPosted: Mon Jul 17, 2006 8:22 am
so 94 elantra eh?!
thanks
1989 colt gt
PostPosted: Fri Jul 21, 2006 4:59 pm
i had the toe out issue, i even adjusted the tie rod ends within 1/2" of the end of the threads and still had severe toe out, couldnt figure out why, I threw my old control arms on and problem solved, but nobody else has had this problem as far as i know, just be careful.
PostPosted: Fri Jul 21, 2006 8:15 pm
I'm wondering if somehow my tierod ends have more thread than yours did. I know I replaced them a couple years back with just "off the shelf" stuff... Do you have power or manual steering? I have power just wondering if thats the difference...
PostPosted: Sat Jul 22, 2006 11:42 am
This is sounding close to my problem. I can not adjust toe and my tie rods ends are almost all way out. See my posts in Inner Tier rods thread.
My inner/outer tie rods are same length as a few other people's. My steering rack (power) is same. I haven't tried replaceing control arms as yet or Struts, maybe struts are bent enough to F**k it up on me!
Bryan
92 Laser RS AWD
PostPosted: Tue Jul 25, 2006 4:46 pm
I have a manual steering rack. That might explain things.
PostPosted: Tue Jul 25, 2006 11:09 pm
As far as I know, my control arms are stock Colt ones. If I measure from the outer bottom edge of ball joint on bottom of control arm to the front bolt where it bolts to frame, it is 14" give or take a wee bit.
I am going to try a new set of struts to see if I can cure my problem, it is driving me nuts
Bryan
92 Laser RS AWD
