It is currently Mon Oct 27, 2025 6:36 pm
 Post subject: Fuse box problems
PostPosted: Thu Jul 13, 2006 7:40 pm
I know to alot of you think this is probly a noob question but my 90 dsm harness does not plug into the 90 colt fues box also the pos battary cable for the colt fuse box is built into the fuse box i have searched for hours and can not find anything about this . So what i need to know is what do i do to wire the colt fuse box to the 90 dsm harness? thanks for the help in advance ( if anyone can help)
Turboed FwD laser
90 Dodge colt 4g63t swap ,680cc injectors, Greddy Profec-b Spec ll Boost controller, Greddy full auto turbo timer, Apex'i S-afc ll, Front mount intercooler, 2.5 inch piping, 3" GM MAF/With MAFT
PostPosted: Sat Jul 15, 2006 9:27 am
Here is a writeup I did when I wired my car.
http://www.4g61t.org/phpBB2/viewtopic.p ... 229#133229
Just wire the black/yellow wire from the fuse box to the tab on the starter and connect the cable to the battery. Also be sure to use the starter harness from the 1.5, not the DSM one. Be sure to connect the 3 block fuse (4 block if the DSM had ABS) to the positive battery terminal also.
