It is currently Mon Jun 03, 2024 8:28 pm
 Post subject: clutch problem
PostPosted: Mon Sep 14, 2015 7:01 pm
I have problems with my clutch disc 4g61t engine, the disc is worn in the center, or just around the center of the clutch disc is destroyed, which clutch disc would you recommend? my engine is a 1700cc swap with turbo 14b and plans are put a big 16 ... km210 gear box
 Post subject: Re: clutch problem
PostPosted: Tue Sep 15, 2015 2:54 pm
get a fwd dsm flywheel and run a dsm clutch of you liking. you will have a better selection with the dsm setup. I had issues with an act on a dsm. but I used to beat on the car daily I believe it was a 2600, with a full Kevlar disc. I was on a 16g 20lbs and drove it hard a lot.the pressure plate lost 5 fingers I was pissed.
