| How to: Wiring 1990 Talon Harness into C52a Interior http://4g61t.org/forum/viewtopic.php?f=23&t=13766 |
| Author: | netninja2001 [ Sun May 08, 2005 1:31 pm ] |
| Post subject: | How to: Wiring 1990 Talon Harness into C52a Interior |
Ok, I thought i'd post this to eliminate a lot of legwork in looking up connectors and whatnot in the csm and dsm manuals. *NOTE* you will probably still need the factory manuals for other things. First off, here are the connectors I'll be dealing with today. ![]() B = Black R = Red L = Light blue Y = Yellow W = White G = Green First color is the main color and second is the stripe Format: Connector (Wire number) - Function (Color) CSM Interior Harness C-19 (1) - A/C Refridgerant Temp Sensor (BY) C-19 (2) - Self Diagnostics Connector Data (W) C-19 (3) - Self Diagnostics Connector Eng (Y) C-19 (4) - Tachometer (W) C-19 (5) - Temperature Guage (YW) C-19 (6) - Unused (?) C-19 (7) - Battery Backup for ECU (WG) C-19 (8) - Brake Fluid Level Sensor (YG) C-19 (9) - Wiper Switch Power [Ignition Switch On] (L) C-19 (10) - Wiper Switch [Internal Relay] (LY) C-19 (11) - Wiper Switch [Intermittent 2] (LB) C-19 (12) - Wiper Switch [Intermittent 1] (LR) C-19 (13) - Check Engine Light (YL) C-19 (14) - Vehicle Speed Sensor [Reed] (YW) C-19 (15) - Auto Compressor Control Unit (G) DSM Engine Harness ??? ------------->C-19 (1) C-58 (7) W ---->C-19 (2) C-58 (6) Y ----->C-19 (3) C-50 (5) W ---->C-19 (4) C-50 (14) YG -->C-19 (5) Unused --------->C-19 (6) C-50 (3) RB --->C-19 (7) C-50 (8) YG --->C-19 (8) C-50 (2) L ----->C-19 (9) C-50 (1) LW --->C-19 (10) C-50 (10) LB -->C-19 (11) C-50 (9) LR --->C-19 (12) C-58 (8) RG --->C-19 (13) C-51 (4) YW --->C-19 (14) ??? -------------->C-19 (15) I didn't wire the A/C connectors because I'm not going to be running A/C. Feel free to post the correct wire connector relating to the A/C system as well as the mysterious wire #6 on the C-19 connector. |
