| Parts Listing: Swap from a 4g15 to 4g63t using C50 Chassis http://4g61t.org/forum/viewtopic.php?f=23&t=1303 |
| Author: | PaulMezz [ Wed Dec 31, 1969 7:00 pm ] |
| Post subject: | Parts Listing: Swap from a 4g15 to 4g63t using C50 Chassis |
Hey guys, here is a cut and paste of a modified cut and paste from the conversion post from the FAQ. I'm talking to the lucky star importer guys about what I need for a conversion if I drive up from NY and go for a weekend swap. I need to make sure I have all the parts... scratch that... all the RIGHT parts so I can drive back when the weekend is over. Does anything look like it is out of place in the list below for a conversion? Thanks -paul Complete engine from an 89-94 Mitsubishi Eclipse Turbo Side mount intercooler and all stock piping Upgraded fuel pump KM-210 transmission. (Turbo Colt/Mirage, 89-92 Galant) 89 Mirage Turbo transmission/engine plate 1G FWD Turbo flywheel, or stock Colt/Mirage turbo flywheel Any AWD clutch setup works well Engine wiring harness from Eclipse Starter from any Eclipse turbo Injector resistor from same year Eclipse (silver box with 4 wires going into it, mounted on firewall) Same year ECU and MPI relay Timing belt motor mount from 89 Mirage Turbo Rear metal motor mount from 89 Mirage Turbo 89 Mirage Turbo complete transmission mount I also believe I need halfshafts from a 89 turbo colt too. |
| Author: | LILEVO [ Wed Dec 31, 1969 7:00 pm ] |
| Post subject: | |
You can use the Colt turbo axles or the 1.5L axles. I'm using the 1.5L axles right now and am having no problems with them. If you can get your hands on a set of 1.6L turbo axles, do that. |
