It is currently Wed Apr 24, 2024 11:41 pm
 Post subject: headlight switch problem
PostPosted: Wed May 24, 2017 10:20 pm
I need help does anyone know how can I make my headlight switch to work. I replaced my headlight column switch ones w/ cruise control but the headlight doesnt work same as a turn signals but the wiper switch work flawlessy. what could be the problem I dont mind making the cruise control to work I just need the headlight and turn signals. Are there wiring diagrams or could this be the a board problems?
Btw, the high beam work, but the park light and low beam and the turn signals dont work
PostPosted: Sun May 28, 2017 7:34 pm
The turn signals in my colt had the same issue, I took the whole unit out of my car, eventually to reveal the circuit board that the turn signals activate off of, then I noticed the contacts had some corrosion on them, so I lightly sanded them to metal again, then I put a light coat of dielectric grease over the moving parts. so far no issues been about a year hope this helps.
you might have other problems, but thought I'd share what worked on my car.
Abe
Users browsing this forum: No registered users and 55 guests
