http://4g61t.org/forum/
Base model axles with turbo brakes?
http://4g61t.org/forum/viewtopic.php?f=22&t=40995
Page 1 of 1
Author:  coltdriver92 [ Tue Mar 21, 2017 3:13 pm ]
Post subject:  Base model axles with turbo brakes?
Like the title says, can I run the axles on my base model with the turbo hub/brake setup? I wasn't sure if the spline was the same. Thanks in advance.
Author:  Flying Eagle [ Tue Mar 21, 2017 8:43 pm ]
Post subject:  Re: Base model axles with turbo brakes?
Long way around on this response. Only the matching caliper brackets, calipers and brake rotors are different between the solid and vented rotor setups. All other suspension/knuckles and hubs stay the same at the front of the car.
Author:  Mechacode [ Wed Mar 29, 2017 6:37 pm ]
Yes, the splines are the same.
https://www.phpbb.com/
