It is currently Mon Jun 03, 2024 7:45 pm
 Post subject: 4g61t AWD trans
PostPosted: Thu Feb 18, 2016 8:43 am
anyone here have data on this? what rear end it uses 3.54 or 3.9? are they as strong as 2.0? what size clutch 215mm or 225mm like 2.0? any trans numbers to identify?
 Post subject: Re: 4g61t AWD trans
PostPosted: Thu Feb 18, 2016 12:42 pm
Since the Cyborg was JDM and Australia only (Maybe Europe), you will want to check there. Here is what a quick Google search found:
http://www.automobile-catalog.com/make/ ... /1990.html
Thom
PostPosted: Thu Feb 18, 2016 12:51 pm
Are the 4g61t awd trans the switchable from fwd to awd trans?
94 Mitsubishi Mirage "4dr"
PostPosted: Thu Feb 18, 2016 1:59 pm
The JDM GVR4 were switchable, not sure on the Cyborg.
Thom
PostPosted: Thu Feb 18, 2016 4:20 pm
so from that site it looks like the trans is geared like the 1990 galant GSX n/a . only 5th gear is lower . now I wonder if the bell housing is same size? did galant gsx use 215 or 225mm clutch? anyone know that? better yet are there any galant gsx left in usa driving around that might need a trans?
PostPosted: Thu Feb 18, 2016 8:42 pm
It is essentially the same trans a GSX, W5M31 is equivalent to the f5m31 in FWD form. It is weaker and not like the turbo version w5m33 and f5m33 transmissions. No clue about the clutch though, but I would guess it's identical to the turbo 4g63.
PostPosted: Thu Feb 18, 2016 9:59 pm
Seems like there was a member over on GVR4.org looking for a GGSX trans.
Edit: http://www.galantvr4.org/ubbthreads/sho ... =1&fpart=1
PostPosted: Tue Feb 23, 2016 12:56 pm
Thought all the AWD clutches were 215mm? I could be way off, but those were the numbers that come to mind when looking up clutches from years ago.
PostPosted: Tue Feb 23, 2016 1:04 pm
The FWD clutches are the same also. Only the ring gear for AWD/FWD (106/110 tooth) are different between FWD/AWD turbo.
Thom
