It is currently Sat Apr 27, 2024 11:16 am
PostPosted: Tue Jul 21, 2015 1:54 pm
I think we need a parts interchange list of Parts that transfer over from any other cars including t/e/l. Like upgrades on colts.even cars that are easier to find in the junkyard. especially in my area. I guess ill start it off
1991-1995 eagle summit wagon/mitsu expo
Front knuckle, abs or non abs they say they are the same
The reason you want this is for rotors that dont suck to replace.
the option to upgrade to gvr4/dsm brakes.
Use galant vr4 rotors if you are using dual piston calipers and are keeping 4x114.3/stock lug pattern.
Can also use t/e/l 5x114.3 spindle to use 5 lug rims and in this case use t/e/l rotors.remember your rotors are for the calipers. single piston use single piston rotors and dual with dual piston rotors
I also put the gas door release from my 1g talon on my colt they fit exactly the same might be different fron the actual colt one but it works. now i haven't put the release pull handle just yet but idk if there is enough cable to reach as the colts gas door is on the opposite side of the car.ill get back to that as soon as i find time.
1992-1995 Elantra control arms are use for people using the easier to find dsm axels compared to colt gt axels.its a little bit longer .375 or 3/8 (this is from what i have read here). But it pushes the tire outward also that amount.
Please feel free to add on.i am human so if something is wrong please let me know so i can correct it.
Thanks john
PostPosted: Tue Jul 21, 2015 4:13 pm
The elantra lca's are from the 92-95 models.
Users browsing this forum: No registered users and 57 guests
