It is currently Thu Apr 25, 2024 11:33 am
 Post subject: FWD ecu in an AWD
PostPosted: Sun May 03, 2015 11:51 am
so......
any thoughts?
do you think the shift points are different?
I assume everything else should work
 Post subject: Re: FWD ecu in an AWD
PostPosted: Sun May 03, 2015 11:57 am
what do you mean shift points? if its auto then there is a totally diff tcu that controls the shifting.. if its a manual then there are no shift points...
but to answer your question we would need more info like what kinda car.. year..engine size..stock or swapped.. I dont think there is much of a diff between fwd and awd ecu's but if there is its something small like inj size.
a description of the problem you are having (if any) would also help.. or are you just trying to use what you have to get a car running?
PostPosted: Sun May 03, 2015 12:07 pm
sorry....
just playing games with my son.
I have a 93 AWD Auto vista wagon
looking at purchasing a 92 FWD Auto summit
I might want to keep the 92 ECU for future use...... although, it occurs to me as I type that the 92 should have an 8 valve SOHC while my 93 is the 16 valve 2.4.
Your probably right on the injector sizing...... i'll have to check that out.
PostPosted: Sun May 03, 2015 10:56 pm
It's a pretty common thing for auto DSM guys to use manual transmission ECU's as an upgrade. As slowdsm said, there's a seperate computer for the transmission. Yes, injector sizing is different between auto and manual cars, at least on DSM's...no clue on the minivans, but probably not too different.
Users browsing this forum: No registered users and 38 guests
