It is currently Fri Apr 19, 2024 2:07 am
Post new topic  Reply to topic  [ 19 posts ]  Go to page Previous 1 2
PostPosted: Wed May 06, 2015 1:28 pm
want to sell the 14b hotside by any chance?
PostPosted: Wed May 06, 2015 3:10 pm
its got a big crack in it.. but if u want it sure.
PostPosted: Thu May 07, 2015 10:08 am
oh okay :/ finding an uncracked 6cm hotside is nearly impossible
PostPosted: Thu May 14, 2015 8:07 pm
hopefully its just the turbo. super easy fix.
cause valve seals is exactly what the symptoms are. ive had several 4g63t with bad seals. always super high kms. had a few 4g15 too. i had one 4g15 that ran like a champ and had awesome compression and used a liter every couple hundred miles. when you let off the throttle you get huge vacuum, and that pulls the oil through the bad seals.
and im pretty sure theres always a big puff at startup
ive only ever had a bad turbo once and it was the most smoke youd ever see come from an engine. but that doesnt mean its alwats like that
