It is currently Wed Apr 24, 2024 5:55 pm
PostPosted: Fri Apr 03, 2015 7:08 am
Trying to figure out what bearing to buy or did a replacement.
Thanks
PostPosted: Fri Apr 03, 2015 7:43 am
Forgot to mention it's 5 lug.
PostPosted: Fri Apr 03, 2015 8:06 am
Hard to say since they all look similar. Being 5 lug would narrow it down but you would still have Eclipse, Diamonte and I think Galant.
Were you on HMT back in the day with a 3TC corolla and a single axle car trailer?
Mark
PostPosted: Fri Apr 03, 2015 8:23 am
Galant and Galant VR4 were 4 lug, unless converted to DSM hubs from what I can tell. That is the big swap that many owners perform to allow for optional wheel fitment.
Lancer Project files: Image
Lancer Project
PostPosted: Fri Apr 03, 2015 8:31 am
Looks like this one (1992 Talon) listed at the Hollander Store:
Click me
Pics from the GVR4 site:
Click
Different from the spindles listed here at DSMTalk:
Click
PostPosted: Fri Apr 03, 2015 8:43 am
Thanks, kind looks like a DSM spindle. So I'm guessing this is the wrote option as faro a bump steer is concerned?
PostPosted: Fri Apr 03, 2015 9:29 am
Pic thread here courtesty of Coltsfan: Click
PostPosted: Fri Apr 03, 2015 11:18 am
I find this intresting; apparently what you have is a FWD DSM/Galant knuckle. I never knew this before reading Flying Eagle's link to DSMtalk, but the AWD ones have the steering arm higher up. I compared it to all the knuckle images on my "Big Brake Thread" and it was unlike any of them.
http://www.4g61t.org/forum/viewtopic.ph ... =big+brake
PostPosted: Fri Apr 03, 2015 12:59 pm
Okay, so if they are fwd turbo spindles they should be pretty decent for a lowered car.
Now I just have to figure out what's causing the problem. When turning left there is a pulsing /groaning sound. With the car jacked up, and car in gear you can watch the motor wiggle back in forth. Stopping the passenger side wheel from turning makes it stop. It's almost like the CV joint is binding up or is to long. It's a fwd turbo axle, I think the lower control arm is galant, but not sure.
PostPosted: Fri Apr 03, 2015 8:00 pm
You likely have a seized or binding inner tripot joint. Do not drive anywhere like this.
DSM FWD and Galant FWD spindles have issues with being installed on our setup. I can't quantify the change in angles as you corner, but I don't think its a correct upgrade unless you are using a platform specific part, IE DSM AWD getting lowered and installing a FWD spindle because it relates the outer tie rod position better for a lowered chassis.
I am sure there are knuckle height differences and or lower balljoint alignment issues, not to mention pushing the hub further out .... then you can't necessarily use FWD turbo CSM axles with FWD DSM knuckles because it will pull them further out. Maybe it's negligible, maybe not. Just please realise the changes that will happen and if they are bad or good.
I will document this when I find it again. Stick to CSM 3G spindles (1989-1992), Expo and if absolutely no alternative, GVR4.
*Edit Tuners thread: some good info Click
GVR thread showing FWD and AWD knuckle differences with relation to outer tie rod placement.
Click
Login and you should see these:
Pics Click
Click
PostPosted: Fri Apr 03, 2015 8:08 pm
I just verified the AWD and FWD are a different PN in Mitsu ASA.
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Fri Apr 03, 2015 8:15 pm
Yes, they have different Tie Rod arm locating positions.
Pic of Galant FWD and TEL AWD spindle stacked up for arm reference:
Click
