It is currently Thu Apr 18, 2024 8:06 am
PostPosted: Mon Dec 22, 2014 12:40 am
Hi! I just found a 95' Hyundai Elantra with 4g67 at one of my local yards, I was wondering what would be good to take for my Colt GL? I've heard that sway bar is pretty much the same as the GTs, what else? Brake booster/Master Cylinder?
PostPosted: Mon Dec 22, 2014 1:47 am
Im sorry i have no knowledge to help you out with finding goodies. But i have a shameless request. If it uses the same ecu connectors as a dsm/csm would you be willing to snip them with as much wire as convenient so i can make a harness extension for my megasquirt ecu? Im sure it could be stuffed in a flate rate box. I would totally pay shipping and give you a little cash for the effort/cost of part. We can pm the details if your interested
PostPosted: Wed Dec 31, 2014 6:27 pm
the ecu plugs are different
PostPosted: Thu Jan 01, 2015 11:03 pm
1994.5+ the plugs would have changed, because the engine management did. Likely moved away from early style Mitsu.
Cylinder head is also useful for people wanting small combustion chamber and larger ports.
Will help with bumping compression on otherwise 7.8:1 compression 2.0L.
PostPosted: Sun Jan 11, 2015 12:19 pm
I used a brake master cylinder off of a 3G eclipse. It's a bigger piece and bolts right on, you just need one custom line since one of the hard lines connects on the opposite side.
91 Talon TSi AWD- SOLD
91 Mirage 4dr 4G63T -Daily
facebook.com/modicausmc
PostPosted: Thu Jan 15, 2015 5:00 pm
The mounts are good for doing a 4g6x swap, and the rear discs(if availible) can be swapped in with a little modification, you could also just swap the whole engine and tranny. The seats also fit but they look a bit weird. Its a close cousin of the CSM there is probably parts we havent thought of that will fit.
4g61t.com
PostPosted: Fri Jan 23, 2015 6:16 am
Just got the sway bar complete and timing side motor mount, I'm still thinking if swaping to those control arms would be worth since I just installed some brand new KYB excel Gs and top strut holes have been already modified
Users browsing this forum: No registered users and 21 guests
