It is currently Tue Jun 04, 2024 6:05 am
PostPosted: Thu Nov 20, 2014 12:40 am
I compiled a list of NGK spark plugs and thought it might be helpful to some.
All from www.rockauto.com
P means its a projector tip plug
R means its a resistor plug
I think everyone knows on these plugs the higher number means colder range plug
All prices are for one spark plug.
NGK IRIDIUM
-BPR6EIX (NGK 6637). $6.47
-BR7EIX (NGK 6664). $6.48
-BR8EIX (NGK 6747, 5044). $6.48
-BR9EIX. (NGK 3089, 3981). $6.48
NON-PROJECTOR, NON-RESISTOR
-B6ES. (NGK 7432). $1.59
-B7ES. (NGK 1111). $1.69
-B8ES. (NGK 2411). $1.69
-B9ES. (NGK 2611). $1.69
-B10ES. (NGK 7928). $1.69
RESISTOR
-BR6ES. (NGK 4922). $1.59
-BR7ES. (NGK 5122). $1.69
-BR8ES. (NGK 5422). $1.70
-BR9ES. (NGK 3194). $1.70
-BR10ES. (NGK 4832). $1.70
PROJECTOR AND RESISTOR
-BPR6ES. (NGK 7131). $1.60
-BPR7ES. (NGK 5534). $1.59
-BPR7ES. (NGK 2023). $1.74
-BPR8ES. (NGK 3923). $1.59
-BPR9ES. (NGK 7788). $1.70
PostPosted: Thu Nov 20, 2014 5:17 am
Thanks Shawn! I'll move this to the tech archive at some point.
PostPosted: Thu Nov 20, 2014 8:38 pm
there are also the ngk g power plugs. i currently have bpr6egp plugs in my elantra.
PostPosted: Fri Nov 21, 2014 8:27 pm
Stock plugs on most 4g6X engines from 1987-199x were BPR6ES.
Here is the range we most commonly see, and were found as stock or colder range replacements.
Tried and true, and inexpensive.
PostPosted: Sat Nov 22, 2014 12:22 am
They never made the G Power in a colder heat range, you can only get the stock "6" heat range.
Another plug that wasn't on this list are the BPXES, projected insulator, but no resistor. I used to run those plugs for a long time, but then I switched to the BR7ES's.
Users browsing this forum: No registered users and 23 guests
