It is currently Mon May 20, 2024 11:56 pm
PostPosted: Wed Jul 13, 2016 1:34 pm
I've got a problem with my column switch, specifically the light rotary and signal. Then steering wheel lock works itself loose while driving.
The light rotary doesn't click anymore and is loose and you've gotta jar it around to get it to work. The signals would sometimes not contact even though it's in the right position.
