It is currently Sat Apr 27, 2024 1:58 pm
PostPosted: Thu Aug 21, 2014 6:38 pm
I have a stock 89 Turbo Mirage. It was running fine when my wife was driving it and she said it lost power and sounded bad.
After trouble shooting, I found out I had spark, and compression well by compression I mean I pulled the plugs and it shot the spark plug wires out. I've tried a known working resistor and transistor pack. The injector are getting signal according to this little light you can stick in the ends of the injector connectors. While running, I can pull 1 and 2 injectors and no change. I pull 3 or 4, it kills the car. I've tried a different MAS and that didnt' change anything. The idle does get slightly higher when I unplug the MAS.
I'm not sure if anyone else has encountered this problem but I'm at a loss.
George
1997 Nissan 240sx
1970 Datsun 240z
PostPosted: Thu Aug 21, 2014 7:14 pm
Turbo Mirage injector issue: http://youtu.be/gGn5zEPNb_g
George
1997 Nissan 240sx
1970 Datsun 240z
PostPosted: Thu Aug 21, 2014 7:22 pm
have you pulled the top timing belt cover and check to make sure its in time? it sounds like it might have skipped a few teeth.
PostPosted: Thu Aug 21, 2014 8:21 pm
I'd check the timing next. If thats not it, you magically had 2 injectors fail at the same time.
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun Aug 31, 2014 12:18 pm
I had the exact same thing happen before going to MOD. IT STUMPED THE HELL OUTTA ME. Turns out I had rust in my tank and it bypassed the fuel filter and was clogging the rail at the FPR and working back. The rust clogged #1, the. #2 then Eventually #3 until I found the problem. Pull the injectors and spray with carb cleaner if they are clogged
91 Talon TSi AWD- SOLD
91 Mirage 4dr 4G63T -Daily
facebook.com/modicausmc
PostPosted: Mon Sep 01, 2014 7:10 am
Bad coil maybe? It could be sparking but not enough.
