It is currently Tue Apr 16, 2024 11:52 am
 Post subject: No headlights
PostPosted: Mon Jul 07, 2014 3:17 am
I got no headlights at the mo.. All other lights are working properly, I'm gonna get a new headlight relay but if that's not it, what should I be looking at? Headlight switch, is there something else that could be the culprit? Only fuse I see is for all lights, which obviously is working as it should.
TIA.
 Post subject: Re: No headlights
PostPosted: Mon Jul 07, 2014 7:56 am
Aight, figured it out.. Found another relay at the yard, $5 lost there so whatever.. Still no lights. Checked the fuse box inside the car, to my surprise when a horn fuse is out, the headlights are also out. Who would've thought, anyway problem solved 8)
