Yes they work, they are a bit stiff with the stock springs though. I had to cut one coil off of the fronts to get it close to stock ride height. The rears were some work. I tried welding some bushings on the ears, but the welds broke. So I took the ears and bent them around the bushings and drilled holes on the top and bottom, just barely notching the bushings, and put some grade 8 bolts through and clamped them in. fits great, clears the tires and had held up extremely well up here with our crap roads. Its deff a ”sport” ride though. The wife can't ride too long in the car cause her fun bags start to hurt from the bouncing !
![;-)](./images/smilies/icon_wink.gif)
