It is currently Thu Apr 25, 2024 4:28 am
 Post subject: Evo Struts?
PostPosted: Fri Apr 11, 2014 2:17 am
Has anyone used these on a CSM? Will they even fit? They were on a vr4 previously.
 Post subject: Re: Evo Struts?
PostPosted: Fri Apr 11, 2014 6:34 am
viewtopic.php?f=9&t=36123&start=30
Fronts just bolt in. Rears will take some work since the lower mount is different.
PostPosted: Fri Apr 11, 2014 9:31 am
I don't know if you'll want to use EVO struts. I think they'll give you massive 4x4 ride height, and since they are a taller strut, you will have reduced travel if you try to lower it, thus ruining your ride quality.
PostPosted: Fri Apr 11, 2014 11:40 pm
Sweet. I'll slap the lowering springs I'm running now on them and see how it goes.
PostPosted: Sun Apr 13, 2014 3:18 pm
Yes they work, they are a bit stiff with the stock springs though. I had to cut one coil off of the fronts to get it close to stock ride height. The rears were some work. I tried welding some bushings on the ears, but the welds broke. So I took the ears and bent them around the bushings and drilled holes on the top and bottom, just barely notching the bushings, and put some grade 8 bolts through and clamped them in. fits great, clears the tires and had held up extremely well up here with our crap roads. Its deff a ”sport” ride though. The wife can't ride too long in the car cause her fun bags start to hurt from the bouncing ! ;-)
Users browsing this forum: No registered users and 47 guests
