It is currently Thu Apr 25, 2024 3:47 am
Post new topic  Reply to topic  [ 61 posts ]  Go to page Previous 1 2 3 4 5
PostPosted: Sun May 24, 2015 9:22 pm
Last pic shows the hat under the top mount, 180 out.
I assume the issue lies mainly with where the coil end, so as to sit properly in the base?
My BG's are currently sitting 1" lower on one side of my car, hope my car isn't tweaked, because everything lines up properly.
You could cut the spring base end, with like a 1/3" coil cut and it would line up then. If you measure out the number of coils/ coil diameter and can find the
sites that discuss coil spring rates, you can see what spring rate they sent you, and determine if it will affect the height in the end. I don't think it will much.
I want to find the numbers on my spring, not sure I got them before painting them. Twice. Haha.
