It is currently Tue Apr 16, 2024 9:57 am
 Post subject: A/C aluminum lines
PostPosted: Wed Feb 26, 2014 7:43 am
I am re-doing my whole a/c setup. where can I get those OE aluminum A/C lines that runs across the engine bay.
 Post subject: Re: A/C aluminum lines
PostPosted: Wed Feb 26, 2014 7:19 pm
You can't. I've thought about trying to get an a/c setup and the best route IMO is to get some custom lines and use a cheap/popular condenser with it. A/C parts are pretty impossible to buy new now.
PostPosted: Wed Feb 26, 2014 7:35 pm
Any Colt/Summit/Mirage sitting in a yard, that has AC.
Only way to get it short of someone still having the pieces after removal from their car.
PostPosted: Wed Feb 26, 2014 9:04 pm
so the best route would be to get a a/c specialist and have one fab for yourself. does anyone knows and can confirm the diameter of the line of our a/c systems aluminum piping? Thanks
PostPosted: Thu Feb 27, 2014 8:01 pm
Is this a swapped car or original 4g15? Your best bet would be to get the lines from a yard as others have said, then buy a new seal kit and replace all the orings.
PostPosted: Fri Feb 28, 2014 7:33 am
You say you are re-doing your AC, are you saying you already have it? I think I still have all the lines off my 3g if you need any.
