There should not be any hose under the dash, the heater core should be metal tubes that stick out from the firewall into the engine bay.
Do you have coolant puddling/leaking into your dash area? If so, check the heater core for leaks, which is a dash out job ... not sure how much, but usually the whole shell for most cars/trucks.
Ah right, yep there was coolent driping into the passenger foot well.
Thanks for that, i can pick another one up from down the road... i guess iv got two dashes to take out
