Coilover and wheel wheels/offset thread http://4g61t.org/forum/viewtopic.php?f=22&t=37429 |
Page 3 of 4 |
Author: | Shawn J [ Sat Jan 31, 2015 5:42 pm ] |
Post subject: | Re: Coilover and wheel wheels/offset thread |
I run 225/50 tires on 16x7 wheels with +40 offset. My car is slammed in coil overs and the wheels are tucked in the fender still. However I did have to remove the front inner fender liners and roll the fender lip. It's a tight fit when lowered. |
Author: | Flying Eagle [ Sun Feb 01, 2015 11:25 am ] |
^^^ Can you go lock to lock without hitting the inner frame area? I've contacted the inner frame with 196 65 14, on stock turbo turbine rims. I try to stay off lock to lock anyways, just as a general rule of palm. |
Author: | Shawn J [ Sun Feb 01, 2015 10:30 pm ] |
Only very very slightly. Only enough to brush the dirt off in one spot. Not a big deal if you ask me. |
Author: | debow_8787 [ Mon Feb 02, 2015 1:12 am ] |
i run 225 45 16 +20 xxr 521 on koni struts hypertech springs and coilover sleeves . this pic is be for i got a aliment and my camber plates are maxed out but now it is .2 degrees if i remember right. |
Author: | mikbik [ Wed Feb 11, 2015 7:21 am ] |
this is the only wheel avail. im looking for. 15x6.5 wheel what offset is better +35 or +42? |
Author: | CaptainTonus [ Wed Feb 11, 2015 10:30 am ] |
+42 |
Author: | Keane [ Wed Feb 11, 2015 10:41 am ] |
×42 |
Author: | DSMERwCOLT [ Wed Feb 11, 2015 1:26 pm ] |
Quote: i run 225 45 16 +20 xxr 521 on koni struts hypertech springs and coilover sleeves . this pic is be for i got a aliment and my camber plates are maxed out but now it is .2 degrees if i remember right.
What bolt pattern and rim width do you run? 16x7 +20?
Author: | xxNocturnalxx [ Wed Feb 11, 2015 10:01 pm ] |
It's 16x8. |
Author: | debow_8787 [ Sat Feb 14, 2015 7:55 am ] |
it is 4x114 16x8 +20 with a 225 45 tire |
Author: | DSMERwCOLT [ Mon Feb 16, 2015 8:33 am ] |
^this is what I am going to try on the Red Summit.....need something in gold |
Author: | Blackgsx01 [ Mon Aug 17, 2015 11:09 am ] |
So I'm almost complete with my 4wheel 5lug conversion,rear disc and 94 front big brake conversion on my 92colt hatch. Next in line is wheel setup. What minimum size rim/offset would I need to run to clear the dual piston calipers in the the front? |
Author: | xxNocturnalxx [ Mon Aug 17, 2015 12:22 pm ] |
I run 15x7 +34 and it clears by a cunt hair. 16" will clear for sure. |
Author: | Blackgsx01 [ Mon Aug 17, 2015 1:34 pm ] |
Quote: I run 15x7 +34 and it clears by a cunt hair. 16" will clear for sure.
Your also running the 94 eclipse dual piston calipers? |
Author: | xxNocturnalxx [ Mon Aug 17, 2015 3:42 pm ] |
Quote: Quote: I run 15x7 +34 and it clears by a cunt hair. 16" will clear for sure.
Page 3 of 4 | All times are UTC-05:00 |
