http://4g61t.org/forum/
De powered a steering rack properly
http://4g61t.org/forum/viewtopic.php?f=22&t=36269
Page 1 of 1
Author:  ColtiXim [ Sun Apr 08, 2012 4:41 pm ]
Post subject:  De powered a steering rack properly
I have done the Miata mod for my steering, but i have found another way for your safety !
First, the Miata mod :
http://flyinmiata.com/tech/depower.php?x=1
http://www.dsmtuners.com/forums/article ... -rack.html
Second, how this stuff work :
http://auto.howstuffworks.com/steering4.htm
The solution, soldering the torsion bar :
http://www.motoiq.com/magazine_articles ... -rack.aspx
I have rebuild my steering rack and done this mod :
Add grease for rust protection only :
I'm in peace now 8)
Author:  Flying Eagle [ Sun Apr 08, 2012 8:05 pm ]
Post subject:  Re: De powered a steering rack properly
This post is amazing, first time I have heard of someone here actually welding the torsion bar.
Good to know that this is the mod required to maintain direct input, with no slop, when de-powering a power steering rack spool valve.
Author:  ColtiXim [ Mon Apr 09, 2012 4:40 am ]
Especially to be more solid, imagine if the torsion bar break !
The power steering fluid help to keep pressure in the spool valve and the torsion bar work normally.
Drain the fluid and you have a weakened torsion bar system.
Author:  UnderPSI [ Mon Apr 09, 2012 9:08 am ]
This is pretty cool, but miatas are all power racks hence the write up. It's a thousand times easier just to swap in a manual rack.
Author:  CSM Shaun [ Mon Apr 09, 2012 11:09 am ]
The manual rack requires more turns to go lock to lock. For a drag car this isn't a big deal but it is noticeable for a daily or autocrosser.
Author:  UnderPSI [ Mon Apr 09, 2012 1:22 pm ]
I am very aware of the gear ratios. It works out to be 3 full turns lock to lock for the power assisted rack and 4 1/4 turns lock to lock for the manual rack. I may do this in the future but since I just got an alignment it's gonna have to wait. Besides it isn't really that bad without the mod, I've certainly parked worse.
https://www.phpbb.com/
