| te04h turbo, can I use it? http://4g61t.org/forum/viewtopic.php?f=22&t=36159 |
| Author: | Peppi_C50 [ Fri Mar 16, 2012 6:27 pm ] |
| Post subject: | te04h turbo, can I use it? |
I've bought I turbo this week. Today I get it. It's a TE04H Turbo. Is it possible to use this turbo for a 4G63? I searched via google, I only know the turbo are in 2,5L engines... Does somebody use this turbo? Sorry, but with turbos I've got no experience. |
| Author: | CaptainTonus [ Fri Mar 16, 2012 11:30 pm ] |
| Post subject: | Re: te04h turbo, can I use it? |
I don't know very much about these turbos, but I'm guessing the center-section of this turbo is different than the TD04 and/or TD05 turbos that come on 4g61/4g63's. This matters because the center-section is where all your oil and water lines hook up. I also have no idea if the flanges are correct to bolt up to a 4g63. Post up a picture of it, if you can. |
| Author: | Peppi_C50 [ Sat Mar 17, 2012 6:57 am ] |
sorry, of course, here the pics. ![]() ![]() ![]()
| Author: | Gizmo [ Sat Mar 17, 2012 7:18 am ] |
It looks like a turbo for subaru? I may be wrong.. |
| Author: | DarkHorse [ Sat Mar 17, 2012 3:36 pm ] |
That flange is k-car/omni style (also confirmed by the chrysler badge on it), its very close to T3 but with one bolt moved further out. If I recall from the early days of turbocharging random stuff (circa 2002 around here) you CAN redrill the hole closer in and use a T3-flanged manifold. THe problem is that these are really small turbos that never put out much boost, which is why they were used primarily on D-series ghetto-fab Hondas. (see: www.homemadeturbo.com back in the day). Will it run on your motor? sure. Will it be right for it? no. Hope that helps ~Joe |
| Author: | CaptainTonus [ Sat Mar 17, 2012 3:42 pm ] |
Yeah, this would be very difficult to adapt to a 4g63, and definitely not worth the time or the effort. |
| Author: | Peppi_C50 [ Sat Mar 17, 2012 4:53 pm ] |
Hm, ok, now I know why I get it so cheap from a CSM owner Thanks for your answers! Other questions btw. Where can I see on a td05h turbo if it's a 14b or 16g or something else? sorry for the noob question. |
| Author: | ColtiXim [ Sat Mar 17, 2012 5:47 pm ] |
Look here for pictures : http://www.4g61t.org/forum/viewtopic.php?f=6&t=33399 Also for the part number stamped on the compressor housing : 14B 49178-01010 49178-01030 49178-01400 49178-01410 Small 16G 49178-01520 49178-05200 Big 16G 49178-01420 Evo I Big 16G 49178-01450 Evo II Big 16G 49178-01460 Evo III Big 16G 49178-01470 |
| Author: | DarkHorse [ Sat Mar 17, 2012 6:01 pm ] |
Quote: Hm, ok, now I know why I get it so cheap from a CSM owner
see where yours says TE04H? a TD05 will be in the same general area.
| Author: | Peppi_C50 [ Sat Mar 17, 2012 6:02 pm ] |
Ok, thanks a lot! |
