It is currently Fri May 03, 2024 9:04 pm
 Post subject: my engine will not start
PostPosted: Thu Mar 20, 2003 8:51 am
so, now I have finaly tried to start up my engine.
it didn't work!
I got spark, I get fuel up to the fuel rail, but no fuel comes into the cylinders. the injectors are dry as dirt!
what could be the problem?
anyone?
I bet I could find som answers if I searched, but I don't know what to search for, that's why I am asking this question!
Thanks alot guys!
/Dan from Sweden
PostPosted: Thu Mar 20, 2003 9:30 am
The Injectors are not getting a signal from the ECU to open. Start tracing things...
PostPosted: Thu Mar 20, 2003 9:31 am
any idea on where to start looking?
PostPosted: Thu Mar 20, 2003 10:56 am
1) Resistor pack
2) Check to see if the signal for the injectors is getting to the harness.
3) ECU good?
4) ECU ground?
Etc etc etc. I would check to see if the injectors are firing. That would be my first stop.
PostPosted: Thu Mar 20, 2003 12:27 pm
mpi relay, & fuse?
PostPosted: Thu Mar 20, 2003 4:35 pm
problem solved! :oops: :oops: :oops: :oops:
I had forgoten to plug in the CAS
when I realized that it fired right up!
such a relief
thanks anyways
