It is currently Fri Mar 29, 2024 12:20 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Wed Mar 12, 2003 12:45 am
Well whatever you do, make sure you do a compression test before you yank the head off. I'd hate to see someone go through all that BS and find that it was just a cracked rocker cover or some such.
If its only leaking under boost it may be that your getting alot of blow-by which is pressurising the crank case and forcing oil past the rocker cover gaskets - at least its a theory. A leak down test will tell you what condition the rings are in.
