figured i'd make a post here so that people not reading my thread in the members section could learn about this too.
a few months ago silverls was wondering if it was possible to swap the 4x114.3 bolt pattern on a 3G CSM for the 4x100 setup on the 4G CSMs.
i was interested because i had a nice set of 4x100 13" rims wrapped in R-Compounds, and the idea of having the non-captive brakes from a 4G car was appealing to me as well.
89mirageman mentioned in silverls's thread that it might be possible to just bolt everything together, but no one had tried yet. so a quick browse of the local classifieds found me a 4G coupe with a blown engine for 160$ and i was in business.
took me a few months here and there to get around to actually tearing it all apart to try it out. i was spurred on recently due to the local car club announcing the spring autocross season. figured if i wanted to compete with my new R-Compounds i should get off my ass :\
so i tore it all apart, got the front spindles off, along with the calipers and the flex lines, and took the rear drums off, pulled the hubs off and took the backing plates along with all the hardware as well.
jacked up the back of my car, took the drums off and stopped for a second. decided i should make sure the rear hubs really did fit, so i slid them on the rear spindle and it fit fine.
tried the drum on it as well as a 'yeah right, can't be that easy' kind of joke, but lo and behold, they slid right on. perfect. bolted the hubs on and threw the rear tires on.
done that part.
started tearing the front end apart after that. got everything off and set the spindles next to one another to eyeball compare them. looked pretty close, other than the arm for the tie-rod end. the boots on my steering rack are busted anyway, so i just flipped the tie-rods over and bolted them onto the new spindles.
everything went together flawlessly.
i tried to run the flex lines for the 4G car in place of the 3G line, since they used a banjo bolt(wasn't sure i could swap that, thought i had to keep the banjo setup), but after rounding off the nuts on the brake hard-lines, i had a bit of an anger fit and just tried the 3G flex line in the 4G caliper. worked fine, wish i'd known i could swap out banjo bolts in the first place :\ would have saved me some time and frustration.
the flex lines were a little twisted after putting the calipers on, but nothing bad enough to worry about.
wish i'd taken some more pictures of the front end while it was going together, but it got dark, i got frustrated and just threw it all together as fast as i could without thinking to take anymore pics :(
so how did it turn out?
like this:
only issue that came from installing the spindles was a 0.50 degree toe out on each side, though turning the tie-rods in a half turn to flip them over should fix that. no positive camber issues, in fact i still have a degree and a bit negative in the front from the lowering springs.
so 4G spindles seem like a nice upgrade from captive brakes, since these are most times easier to find than the VR4/Expo spindles, and the rest of the VR4 goodies just bolt onto these. you can also press the 4x100 hubs out and press Expo 4x114.3 hubs back in using the 4G bearings.
from MirageForums.net:
Basically you remove the seal and a large snap ring, then press the hub and bearing out. Grab a 4 lug hub from a 92-96 expo, colt vista or summit wagon or a 89-93 Galant or a 5 lug hub from any 90-94 eclipse, talon or laser. Buy a new wheel bearing and inner and outer seals for the mirage and press it all back together. Nothing hard about it, just time consuming. I actually welded up a plate that screws onto the end of my Harbor Freight slide hammer/snatcher. I unbolt the caliper and knock the rotor off at the junkyard, remove the 32mm axle nut and bolt up my plate and after a few hard snatches the hub comes flying off. This way you don't have to buy the entire knuckle and bring it home to press out.
thanks for reading :)
quick update: added 4x100 to 4x114.3 hub swap information, solution to the toe out, and new image links.
TL;DR - 4G spindles and brakes fit on 3G cars, have fun.
