SuperPro bushings: Order here! http://4g61t.org/forum/viewtopic.php?f=22&t=25870 |
Page 1 of 7 |
Author: | LILEVO [ Thu Jul 24, 2008 6:50 pm ] |
Post subject: | SuperPro bushings: Order here! |
I got a hold of Jesse at Revolution Motorsports. He can get us super pro bushings from Australia. They will take 2-3 months to get here (which is fine with me) If you want some, tell me which part numbers you want. I will then tell you the total cost to paypal me. I am getting: SPF1160K SPF1140K Which are really the only two control arm bushings available for the 1990. |
Author: | 89coltgt [ Thu Jul 24, 2008 8:21 pm ] |
Post subject: | |
Is this a special order through Jesse? |
Author: | CaptainTonus [ Thu Jul 24, 2008 8:24 pm ] |
Post subject: | |
PM sent. Does SuperPro have an all-inclusive kit for a C53? |
Author: | LILEVO [ Thu Jul 24, 2008 8:31 pm ] |
Post subject: | |
Well he is ordering them. Nothing much more "special" about it. I can't just call up superpro and order them myself. |
Author: | Berserko [ Fri Jul 25, 2008 1:27 am ] |
Post subject: | |
Or you can call whiteline and they can be here in 2-3 weeks... |
Author: | MattGSR [ Fri Jul 25, 2008 1:43 am ] |
Post subject: | |
I'm in, these are the bushings i need. SPF1160K SPF1140K SPF2092B-4K SPF0427K (i need 2 of these please) let me know how much, where and when to send payment. thanks Jason |
Author: | stealthtt24 [ Mon Aug 04, 2008 7:16 pm ] |
Post subject: | |
What ones are the sway bar to chassis bushings? |
Author: | LILEVO [ Mon Aug 04, 2008 7:39 pm ] |
Post subject: | |
I think he said the 1160 is $50 and the 1140 is $40. Might be flipped. Beserko, I looked on the whiteline site and couldn't find any bushings. Do you have someone you dealt with in the past? |
Author: | Berserko [ Mon Aug 04, 2008 8:11 pm ] |
Post subject: | |
I just called and ordered and they sent them... |
Author: | stealthtt24 [ Mon Aug 04, 2008 8:12 pm ] |
Post subject: | |
What number did you call? |
Author: | Berserko [ Mon Aug 04, 2008 8:40 pm ] |
Post subject: | |
Quote: What number did you call?
http://www.whiteline.com.au/location.htmHow to Contact Us LOCATION: 4 Warringah Close, Somersby. 2250 NSW. Australia Google Map PHONE: (02) 4340 2355 1300 88 2355 int+ 61 2 4340 2355 (international) FAX: (02) 4340 2466 ORDERING METHODS: Our products can be purchased via our secure Webstore (credit card only) HOURS: Normal opening hours (Australian Eastern Standard time): Monday to Friday - 8.00am to 5.00pm |
Author: | LILEVO [ Mon Aug 04, 2008 8:46 pm ] |
Post subject: | |
For 89-92 Lancer, this is all I see: F Brace-strut tower alloy adj KSB556 F Camber adj bolt kit-12mm KCA412 +/- 1.5 deg F Caster adj kit - control arm. excl GSR KCA323 adds +1.0 deg F Spring-coil lowering kit - Control 70082 R Panhard rod kit-adjustable KPR013 off-car adjustable R Spring-coil lowering kit - Control 79118 R Swaybar-h/duty Blade adjustable. CB sedan coupe with beam rear BMR68Z R Swaybar-heavy duty. CB sedan coupe with beam rear BMR68 |
Author: | stealthtt24 [ Mon Aug 04, 2008 8:48 pm ] |
Post subject: | |
Im looking at Hyundai Elantras, since i'm using the same sway bar. |
Author: | Berserko [ Mon Aug 04, 2008 9:39 pm ] |
Post subject: | |
Trust me I've ordered from them twice you just need to call them.... |
Author: | Berserko [ Mon Aug 04, 2008 9:44 pm ] |
Post subject: | |
Supposedly Tien USA is the distributor for SuperPro in the USA now... |
Page 1 of 7 | All times are UTC-05:00 |
